![]() | Home > Maintenance & Modifications > Air con grill on non air con Puma.. |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
The recessed part on the side of the grille should slide in between the two wings. You could add a washer to either side of the slam panel to push the wings out a little or try just to push the grille panel in at the side. If genuine it’s only made of fibreglass so will usually flex a little, and as you push will pop in between the two wings. Ray
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
There aren't different versions of the grill panel but there probably are of the of the slam panel. As Ray says though, nothing that can't be resolved with a bit if packing and ingenuity. Darren
| NickMSM Member Since: 18 Aug 2016 Location: W Sussex Posts: 111
Thanks - I've got it on, but can't for the life of me get the far left screw holes to line up with the slam panel. Seems to be catching at the very top of the surround where it meets the wing. Will have another look but might have to trim it slightly
On another note, what are the bolts needed to attach it on the sides to the bracket? One on each side towards the bottom of the surround. |
They are actually very large screws, no.14 x 3/4", that screw into spire nuts clipped on the end of the brackets. The part number for them is AB614065L.
https://www.lrworkshop.com/parts/AB614065L Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Brilliant, thanks
| All times are GMT |
