|  | Home > Maintenance & Modifications > Another day another problem |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060    | Start with filters. Including the often forgotten fuel filter
 If still a problem, try running fuel prime procedure before starting. | ||
|  8th Sep 2020 8:50pm |
| LiftedDisco Member Since: 17 Aug 2014 Location: Towcester Posts: 357    | And/or a squirt of brake cleaner in the injector loom?
 That would probably be my first port of call... | ||
|  9th Sep 2020 5:53pm |
| Ben-9090 Member Since: 05 Apr 2020 Location: Norfolk Posts: 8  | Getting new filters tomorrow so I will put them on. I read a bit about the injector loom but don’t understand what is the problem?
 Is it worth just putting a new injector loom on it? Thanks Ben | ||
|  9th Sep 2020 7:23pm |
| LiftedDisco Member Since: 17 Aug 2014 Location: Towcester Posts: 357    | Apologies - not very clear!
 There is a tendency for oil to track back along the injector loom and collect around the pins of the red connector to the ECU... this is the bit that may need checking and cleaning. More info here: https://www.defender2.net/forum/topic4426.html | ||
|  10th Sep 2020 6:59am |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219      | Nice occasionally has a bad connection on one of the injectors, so have to whip the rover cover off and give it a wiggle.
 I've slightly bent the pins so they (hopefully) make a better connection in the plug.... time will tell, has been OK for a while now. | ||
|  10th Sep 2020 8:04am |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692      | Same problem 8 years ago - connector pin loose on injector. Remove and bend a bit all connectors on the injectors "loom" below the valve cover, and replace also 2 O-ring on the "engine out" connector of this loom and still OK and no more oil in ECU.
 The oil os not a big problem, just ugly, big problems are the tiny connectors on the injectors - the have to wistand approx. 25A of current together with high temperature inside of engine. If you remove the valve cover, check also the injector clearance. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo  | ||
|  11th Sep 2020 5:08am |
| Ben-9090 Member Since: 05 Apr 2020 Location: Norfolk Posts: 8  | So update.
 Fitted new fuel and air filter it made no difference. Everyone talking about injector loom so ordered a new one. Fitted tonite and still no different. Checked the old loom and no oil in the connector outside of the camshaft cover or in the red plug in the ecu. I know everyone says this but it was driving fine until the other night when I turned her around on the drive to do another job on the defender. Another question. Does anyone actually drive their defender? I just seem to be fixing things then finding something else wrong with her. | ||
|  11th Sep 2020 6:53pm |
| Posting Rules
