![]() | Home > Td5 > R380 gearbox oil to avoid crunch/grind |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
I got a crunch going from 1st-2nd and from 3rd-2nd if I wasn’t careful.
I put Redline synthetic manual transmission MTL 75w-80 GL4 in mine and it’s loads better. Of course it might just be that it’s brand new oil in there now that’s made the difference 🤔🤔 2002 td5 90 county hardtop |
Not something I would ever think of doing in a vehicle with an R380! ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
I also run Redline MTL. Excellent stuff. The trick to not crunching is slow and smooth shifts with a slight (momentary) pause in neutral between each gear change Good synth gear oil and do that and you won’t crunch em
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
charisme1 Member Since: 23 Oct 2019 Location: Paris Posts: 43 ![]() ![]() |
Hi jay and Thanks for your speedy reply. What was before Redline to see this difference ? LR MTF94 or ATF ? Merci 😀 |
Hi 4RF and Thanks for the trick ![]() What was before Redline to see this difference ? LR MTF94 or ATF ? Merci 😀 |
MTF94
