Home > Maintenance & Modifications > Defender bulkhead rust proofing
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Hello,
I need some advise in regards to preventing the bulkhead from rusting. Would you drill any holes to get cavity wax in? Or removing the the hinge bolts and grommets be Sufficeint ? I don’t like the idea of drilling holes but I’d prefer that than find the bulkhead rotten.
Alex
Post #696043 25th Mar 2018 1:21pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I have always removed the hinge bolts and used a pressure gun to inject rust proofing fluid upwards into the bulkhead leg from the bottom. Not had any problems doing it this way.
Post #696084 25th Mar 2018 6:15pm
Alextd5
I have sprayed ACF-50 and dinitrol cavity wax in mine. Through the door hinge bolt holes and through the wiper grommets, but I’m not satisfied it’s enough. I know people do drill small holes to inject it in. But I’m reluctant to do so. So was hoping someone would have done it somewhere I haven’t.
Post #696089 25th Mar 2018 7:04pm
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
There is frame inside of bulkhead which divides it into internal areas. Spraying through the door hinges and wiper grommets covers less than half of those areas. I would drill holes to extend healthy life of the bulkhead.
Would you share information on where the holes were drilled?
Post #854178 4th Sep 2020 5:35am
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Mike at Britannica Restorations has just covered this:
Post #854596 6th Sep 2020 7:55pm
Mdm
i wouldn't drill any more holes.
just use what's there with your rust converter and then wax of choice.
its better than nothing.
Post #854598 6th Sep 2020 8:00pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
This is covered in the Military Anti Corrosion manual. Rgds.
Chris
Post #854607 6th Sep 2020 8:46pm
qwert
Thanks! How have I missed that?
Nearly drilled holes from outside Smile . Now I have a much better plan.
Post #854676 7th Sep 2020 11:11am
excossack
Is there a copy of this floating around? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #854680 7th Sep 2020 11:27am
Pacha
 Rgds.
Chris
Post #854689 7th Sep 2020 12:12pm
excossack
Cheers Chris 1999 Defender TD5 110
Regards
John M0VAZ
Post #854704 7th Sep 2020 2:17pm
