![]() | Home > Maintenance & Modifications > Defender bulkhead rust proofing |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
I have always removed the hinge bolts and used a pressure gun to inject rust proofing fluid upwards into the bulkhead leg from the bottom. Not had any problems doing it this way.
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 ![]() ![]() ![]() |
I have sprayed ACF-50 and dinitrol cavity wax in mine. Through the door hinge bolt holes and through the wiper grommets, but I’m not satisfied it’s enough. I know people do drill small holes to inject it in. But I’m reluctant to do so. So was hoping someone would have done it somewhere I haven’t.
qwert Member Since: 26 Aug 2010 Location: Switzerland Posts: 33 ![]() ![]() |
There is frame inside of bulkhead which divides it into internal areas. Spraying through the door hinges and wiper grommets covers less than half of those areas. I would drill holes to extend healthy life of the bulkhead.
Would you share information on where the holes were drilled? |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 261 ![]() ![]() ![]() |
Mike at Britannica Restorations has just covered this:
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1665 ![]() ![]() |
i wouldn't drill any more holes.
just use what's there with your rust converter and then wax of choice. its better than nothing. |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
This is covered in the Military Anti Corrosion manual. Rgds.
Chris |
Thanks! How have I missed that?
Nearly drilled holes from outside ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Is there a copy of this floating around? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
![]() Click image to enlarge Rgds. Chris |
Cheers Chris 1999 Defender TD5 110
