Home > Tdi > Gearbox Trouble??? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2086 |
I think you've answered your own question, though by the sound of it the UJ has probably damaged the prop now.
HTH Mo The Land Rover 90 - Many are called, few are chosen. |
29th Aug 2020 12:20pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
Put it in diff lock, remove rear prop. Does it drive?
29th Aug 2020 12:25pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 297 |
I'm changing the rear prop today so I'll see if it drives in diff lock without it. Luckily I've got another gearbox sat in the workshop.
I'm pretty sure it's the box, just wondered if anyone else has had the same problem. Thanks for the replies. |
31st Aug 2020 8:27am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3213 |
Do you know if you have the cross drilled input gear in the transfer box? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
31st Aug 2020 10:21am |
Got the truck recovered back to the workshop, had a look inside the box and yeah... its the box!
I'd say catastrophic failure.?. Click image to enlarge This is what fell out... Click image to enlarge |
6th Sep 2020 6:51pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1534 |
i have a spare tdi gearbox still in a rusty old disco that runs and can be test driven .
in case your not rebuilding that one or dont have a spare on the shelf |
6th Sep 2020 7:48pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2055 |
If your lucky and have some superglue to hand then you can simply put them back on............
6th Sep 2020 8:15pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
Wow, that's quite a failure!
6th Sep 2020 9:40pm |
Was there any play on the bearings? especially the intermediate bearings take a punishment. Or the collapse tube not set correctly? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
7th Sep 2020 5:42am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
I think catastrophic failure is a good description. Defender 90XS SW
7th Sep 2020 6:35am |
Ouch ! That's a proper job !
7th Sep 2020 9:21am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
Not seen one like that, that is bad 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
7th Sep 2020 10:21pm |
Cheers Mdm, luckily I have a spare, spent Sunday afternoon cleaning it up... Click image to enlarge Click image to enlarge It had been left standing for a month on grass while I found some time to fit new swivel housings, bearings etc. so it either had a helluva oil leak that I didn't spot or just sh** happens! I've decided to rebuild her onto a galv chassis since I've got this far. I'll be starting a build thread to cover it. |
8th Sep 2020 7:46am |
8th Sep 2020 7:47am |
