Home > Puma (Tdci) > VCV
mike.29
 2008 Defender 90 Puma 2.4 HT Epsom Green
VCV
I changed my vcv valve a month ago and not use my Land Rover much since. I have just noticed that is has developed a diesel leak around the valve. When I removed the valve to investigate I discovered that the O-ring on the valve is damaged. Is it possible buy a replacemnt O-ring for or would I need to buy a new valve?
Thanks
 Michael
08 2.4 TDCI Defender 90
61 2.25 Petrol 88" Series 2
53 2.00 Petrol 80" Series 1
Post #854611 6th Sep 2020 8:18pm
It is almost certainly a standard size O ring and can be replaced, the only problem is figuring out the right size. A box of assorted O rings would be cheaper than a new VCV.
Post #854615 6th Sep 2020 8:39pm
Drop an email to PF Jones. I expect they can pop a few in the post for you if you ask nicely.
If that doesn’t work then try Blackwolfs suggestion above. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #854618 6th Sep 2020 8:44pm
mike.29
Thanks for the advice I managed to get another o ring and changed it over and the leak is gone! Thumbs Up Michael
Post #857517 22nd Sep 2020 9:14pm
Wink Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #857522 22nd Sep 2020 9:32pm
