![]() | Home > Maintenance & Modifications > Td5 Provent 200 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Evening all!
I've just received my new Provent 200 from LRA. I've had a quick gander at mounting options but just thought I'd ask here to see if anyone has mounted one to a Td5 defender and if so, how/where did you mount it? I think the N/S wing support bracket looks like a good option as there is plenty of room and the pipe run would be very straightforward. I assume that to work correctly it needs to be level in both planes? Any experiences/thoughts greatly received ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I have one George I’ll take pics tomorrow 👍
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Mine is mounted to a bracket on the heater box:
![]() The height is quite limiting when you start trying to fit it in! 02' 110 TD5 Double Cab Rebuild Thread |
I'm hoping for a cleaner intake tract from turbo compressor onwards
Collects a surprising amount of oil. My intercooler and intake had quite a film of oil before i fitted the Provent. Since fitting it (12k ago) my intake has stayed clean so makes a big difference to this.
I never bothered connecting mine back into the sump, i just drain it out periodically. Steve 02' 110 TD5 Double Cab Rebuild Thread |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17947 ![]() ![]() ![]() |
If you see what comes out you won't want to put it back in your sump.
I mounted mine on the wing bracket
![]() ![]() Click image to enlarge ![]() Click image to enlarge I dropped a pipe with a tap down past the wing liner so I can empty oil out from under the wheel arch regularly and cleanly ![]() My build thread http://www.defender2.net/forum/topic17615.html |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Perfect, thank you guys! I'm definitely liking the wing brace mounting option. I'll have a look at doing that later
Just to wrap up the thread I've modified my wing stay bracket to accommodate the Provent. Just need to get some pipe ordered and it's another job done
Is there a specific TD5 kit for this? Tempted to do mine as well.
I don't believe there is. Having said that you could fit one with very basic tools if needed
