![]() | Home > In Car Electronics > 10AS alarm/immobiliser question. Any experts please? |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
Yes the buttons are for the alarm and the fob for the immobiliser. In practice I never set the alarm (by using the buttons), although I think one does have a bearing on the other, but the fob proximity alone allows starting the vehicle.
The fob will run out of battery within 2 years, which having it accessible might be helpful to change. Otherwise you could get the 10AS programmed to turn the immobiliser off. (Presuming of course the Disco is the same as the Defender) |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
Thanks for the feedback. I am going to experiment this weekend by leaving the fob close to the ignition barrel and then locking/unlocking/starting the vehicle with the key. Given the vehicle use, I'd prefer not to have the fob on a key ring anyway as someone is bound to drop it in the reservoir at some point!!!
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
There is a coil that wraps around the ignition barrel and this picks up a signal (they call it passive immobilisation) from the key fob when it's close enough (basically it needs to be on the keyring, not just inside the vehicle). Not quite sure what the technology is but that's how it works.
Points to consider which apply to most vehicles of this age - You can lock it with the key but you still need to unlock it with the fob or the alarm will go off - However, locking it with the key disables the interior sensor e.g. if you leave a dog in the car - The immob is disarmed EITHER with it being on the keyring (passive) OR if you press the unlock button and turn the key on fairly quickly - but you do need the key fob My father has a June 1998 build 300Tdi and his doesn't have alarm or immobiliser as an export spec, so you could de-electronics the whole lot if you wanted to and just have a dumb key. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Thanks for the information bogmaster. If the alarm needs disabling with the fob after locking with the key, then this scuppers my plan of cable tying the fob inside the steering column plastics
![]() Update : Just found this in an online copy of the user manual for the 1998 YY Disco with a two button fob : LOCKING USING THE KEY Front doors Turn the key towards the front of the vehicle to lock and towards the rear to unlock. NOTE: Turning the key also arms and disarms the anti-theft alarm. Rear door Turn the key towards the right side of the vehicle to lock and to the left to unlock. Locking the doors without activating the alarm By turning the key to the lock position and then holding it in that position for at least five seconds, the doors will be locked but the alarm will remain inactive. Central locking By turning the key in the driver’s door, or operating the locking button on the driver’s door (from inside the vehicle), all the door locks can be operated simultaneously. Door sill locking buttons From inside the vehicle, each door can be individually locked by depressing the appropriate button. NOTE: As a precaution against accidentally locking your keys inside, it is not possible to use the locking buttons to lock the front doors when you are leaving the vehicle - THE KEY OR HANDSET MUST BE USED! This would suggest that locking and unlocking with the key does enable and disable the alarm. Think some experimentation is planned as per original plan. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2530 ![]() ![]() |
Re access to a nanocom. I bet there is a member local to you that has one and would help out programming a new fob. Have a look on the nanocom group buys, see if there are local members and see if they would help out.
