Home > My Defender > An Anorak's Utility Station Wagon
Page 38 of 57 <123 ... 373839 ... 555657>
Re: Axle Retaining Brackets
Pacha wrote:
Thanks for this Darren - something else to go on the list that I didn't realise I needed to do! Laughing
My work here is done Laughing Darren
Post #853446 31st Aug 2020 9:29pm
ChrisDefender
Hi Darren,
Are you able to let me know where you got the axle retaining brackets from, I am struggling to find them online? (mainly as I don't really know what I am looking for!!)
Great job by the way Thumbs Up
Cheers.
Post #853542 1st Sep 2020 10:41am
Part numbers for the brackets are:
- LR068818 LH bracket
- LR068822 RH bracket
Google these part numbers and several suppliers will miraculously appear, also available via ebay sellers.
See also https://www.defender2.net/forum/topic33029.html
Post #853549 1st Sep 2020 10:57am
I plugged the part numbers into eBay, which was the easiest purchasing route (notwithstanding that I've been sent the wrong one!). They cost around £30 each. I also bought new nuts, which are M16 x 1.5 nylocs. Darren
Post #853555 1st Sep 2020 11:11am
ChrisDefender
Many thanks both, I will get a set of those ordered, then work out what to do with them!
Cheers all as ever Thumbs Up
Also read the post as per the link, will this fix apply to my 90 as well as the 110? Cheers.
Post #853558 1st Sep 2020 11:15am
The original recall didn't include 90's but the brackets will fit just the same. Darren
Post #853563 1st Sep 2020 11:42am
ChrisDefender
Cool thank you.
Post #853564 1st Sep 2020 11:48am
Indeed, the original recall not include 90s but they still fail all the same. See https://www.defender2.net/forum/topic55655.html
Post #853568 1st Sep 2020 12:11pm
Is there still an alignment issue whereby the original flanged nuts will not seat correctly?
Post #853571 1st Sep 2020 12:31pm
Almost certainly, yes. A standard nut just about fits into the recess in the bracket but I can't see how a flanged nut would. The clearance is such that I also couldn't get a socket on one of the nuts and had to use an open spanner. Darren
Post #853578 1st Sep 2020 1:04pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Hmmm - I have just received my brackets today and the LR flanged nuts fit the recess.
Maybe the design has changed slightly?
 Rgds.
Chris
Post #853816 2nd Sep 2020 1:53pm
Hmm, ok. I think the problem may lie with the alignment of the two holes in the bracket with those on the axle. When I fitted mine, I put the first nut on without issue but with second, the bracket was positioned such that a socket wouldn't fit over the nut without fouling. I managed to get it to fit with a spanner but it wasn't quite central with the machined flat on the bracket, which leads me to believe that a flange nut wouldn't fit. It's basically a pretty tight tolerance. Darren
Post #853829 2nd Sep 2020 3:14pm
I don't remember any issues with mine when I fitted them either. Maybe the issue is tightening either nut full before the other has seated?
Post #853857 2nd Sep 2020 4:47pm
I'll take another look when I get the replacement for the drivers side. Darren
Post #853936 2nd Sep 2020 10:03pm
Pacha
I have not had time to fit these today but I ran the vernier callipers over the components - there is a good 1 mm clearance on diameter between the O/D of the LR flange nut and the recess in the reinforcement piece. Rgds.
Chris
Post #853938 2nd Sep 2020 10:06pm
