![]() | Home > Technical > leak from front headlining |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Join in the roof between the flat bit and the sloping bit above the cab?
you need a copy of the "water ingress manual" - do a search ... your troubles have just begun ...
take your time, find the leak and fix it properly .. usually water gets into the inner drip rail and ends up on your lap ... known problem, and can be fixed top 3 places 1. around windscreen (at the top) 2. alpine lights 3. front end of gutter where the roof meets the pillar good luck |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Water ingress manual here
https://www.defender2.net/gallery/albums/u...cedure.pdf ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
It's why a lot of Land Rover drivers wear wax jackets !
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Zag, have you got it on quick launch? No rain here in Cyprus to leak through!! Glyn ![]() ![]() |
Check the sloping to flat roof seal first. Glyn, post some pics mate,it years since I was in Cyprus, great place I really envy you ![]() 1968 1/32 scale Britains 109 Pick up. |
I have started a post of my adventures ![]() http://www.defender2.net/forum/topic7859.html?highlight= Glyn ![]() ![]() |
Sorry, not with you Glyn "quick launch" ![]() ![]() |
mr_tdi82 Member Since: 24 May 2011 Location: Henley on Thames Posts: 62 ![]() ![]() ![]() |
the manual makes for interesting reading, i've already plugged numerous leaks with dum dum, even found the large grommet on passenger side footwell was never fitted.
I bet Solihull put that one together properly ![]() |
