|  | Home > Maintenance & Modifications > Install cubby box 110 |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772      | The drinks tray should just lift out and you’ll probably have to drill holes to match up with your own mounting points if that’s your new cubby box picture in your gallery. You don’t need to take the battens off the bottom.    Good luck. You could use the old box to get old hole positions and probably reuse the old spacers if they are the plastic ones. Ray My build thread http://www.defender2.net/forum/topic17615.html | ||
|  9th Aug 2020 4:30pm |
| LandyHelp Member Since: 09 Aug 2020 Location: caribbean Posts: 13  | Yes that is the new boxes bottom and the old one has 4 plastic round tube like feet on the bottom. I will have another look at it. I prefer not to re use the old plastic feet and wasnt keen to take off the mounts on the new box. The drinks tray is fast glued on so will have to prise off.
 Thanks much. | ||
|  9th Aug 2020 4:41pm |
| TD5Neil Member Since: 02 Nov 2017 Location: Cambridgeshire Posts: 42    | The drinks holder is held by 2 spots of glue.  Use a wallpaper scraper and lever gently and it pops out. I knocked/prised the bottom bit off and reused the plastic spacers on mine, using the old one as a template for where to drill. Hope that helps.  Cheers Neil | ||
|  9th Aug 2020 5:25pm |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791      | My drinks tray was glued in. I ended up just screwing up from below into the battens. | ||
|  9th Aug 2020 5:32pm |
| LandyHelp Member Since: 09 Aug 2020 Location: caribbean Posts: 13  | Thanks all, will see if all this works. Doesnt sound too difficult. | ||
|  9th Aug 2020 5:43pm |
| Posting Rules
