Home > In Car Electronics > Aux light switch YUG000540LNF
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
Anyone know the current rating of the load contacts of the above switch...hoping to not have to fit a relay for an LED light rated 1.25 A...
Dave
Post #374881 28th Nov 2014 6:43pm
PaulMc
The heated seat switches of the same design, switch around 7A - so, this switch should be more than capable of switching 1.25A
You should be aware that this switch switches to earth.
There's a wiring diagram, showing how to wire this switch, here - http://www.defender2.net/forum/post6360.html#6360
The design of this switch will cause you problems if you want the switch's tell-tale LED to work, as this is normally fed from the output side of the relay, to pin 5 of the switch.
Without a relay, it's not possible to have the tell-tale illuminate when the switch is on.
I would suggest that you get a Puma heated seat switch (YUF500150LNF), which costs around a fiver new.
Swap the switch front from YUG00540LNF on to the switch body of YUF500150LNF (they both use the Black 5-way switch connector) - and you now have a live switching switch, in which the tell-tale LED is fed from the output side of the switch (pin 4).
A diagram for YUF500150LNF can be found, here - http://www.defender2.net/forum/post306063.html#306063
. Paul.
Post #374914 28th Nov 2014 8:29pm
Dave Bellis
Top man Paul thanks for the info.......all sorted
Dave
Post #374982 28th Nov 2014 11:56pm
Alex - RSA
South Africa 2003 Defender 110 Td5 DCPU Corris Grey
Hi Paul,
I know this is a REALLY old thread, but I am battling to wire some switches and your directions have got me the closest I have come so far.
I managed to get my hands on some Bearmach Momentum One Touch Switches with facias for various LED lights front and back. By following your directions and modifying the internal circuit, separating pins 3 and 4 I have the lights coming on when the switch button is depressed but as soon as I let go the lights go off. So the "One Touch" closing of the circuit is not working as it does with the standard Rear Fog Light switch.
Please HELP !!!
Post #848441 6th Aug 2020 9:56pm
When used for the rear fog light, it's in conjunction with a latching relay. The function isn't built into the switch.
This thread may help:
https://www.defender2.net/forum/post723463.html Darren
Post #848511 7th Aug 2020 10:45am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Latching electronic circuits are available, if you don't need or already have a non-latching relay.
This is for upto 1.5 A:
https://www.conrad.com/p/tru-components-sw...pcs-701240
Post #848585 7th Aug 2020 9:16pm
eliteaccess
Heated seat switch used for a work light switch
Has anyone come across a problem i have found. I am using the YUF500150LNF defender heated seat switch. I have a wiring diagram showing pin 1 perm live, pin 2 switched live from dash lights, pin 3 unused, pin 4 live switched output to accessory and pin 5, earth/ground.
Everything works, apart from when i push a live into pin 2, the green LED doesnt come on. The amber one works fine as does the switch. I have tried a second switch and the same thing happens.
has anyone else come across this?
Post #878666 15th Jan 2021 6:42pm
Likeomg
this is something I need to sort on my switches...
Post #878680 15th Jan 2021 8:15pm
Re: Heated seat switch used for a work light switch
It certainly sounds like it should work Confused Have you tested that you're actually getting 12v from whatever feed you've taken from the instrument lights?
 Darren
Post #878705 15th Jan 2021 9:55pm
eliteaccess
yeh thats the wiring diagram i used. yes deffo have 12v on the input wire for the green backlight.
Post #878708 15th Jan 2021 10:00pm
Not sure in that case, I'm afraid. As you've tested two switches, it suggests there's something more fundamental with the way that you're making the connections but it's difficult to be more specific. Darren
Post #878732 15th Jan 2021 11:19pm
