![]() | Home > My Defender > hanks Double Cab |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 1393 ![]() ![]() ![]() |
There has been a slight oil weep from the transfer box since the day I had the Defender. It looked to be coming from the intermediate shaft/case as is common so I wasn't overly rushed to look at it.
Transfer box is back in the Defender. Serious improvement in terms of backlash and leak free!
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 4878 ![]() ![]() ![]() |
Hank, do you think it was the Ashcroft rebuild kit, output shaft or both, that really reduced the backlash? The rebuild kit is quite a job, whereas the output shaft is a common upgrade I’m thinking of DIYing. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 12457 ![]() ![]() ![]() |
The breakdown of the centre diff thrust washers will have resulted in a lot of backlash in this box. |
As black wolf says the backlash was, without a doubt, coming from the lack of washers in the diff planetary gears which would have allowed the planetary gears to run further "out" (for want of a better term) where they wouldn't mesh properly due to being bevel gears.
Hahaha true dat > 110 XS Double Cab
Recently I've been experiencing the occasional "P0234-00 (28 ) turbo overboost condition" error which puts the vehicle into what feels like normally aspirated / limp mode until the fault is cleared.
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 2681 ![]() ![]() ![]() |
Nicely done. You'll be surprised how much oil it catches. WARNING.
Yeah? I've put a length of opaque pipe on the waste as a temporary measure but will fit a transparent hose and tap arrangement when I get one so I can monitor the waste oil level > 110 XS Double Cab
Rocker cover subcover fitted |
2 questions.
And the final piece of the provent puzzle... Waste drain and tap plumbed to behind the front offside radius arm mounting, retained by a hose clip in an existing hole
Its primary purposes it to avoid comments like those below ![]() > 110 XS Double Cab > Instagram @simonlanemind |
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
