Home > Technical > Anyone know if D2 Anti Roll Bars are the same as Def 110?
bankz5152
as above really chaps!
Post #847036 30th Jul 2020 1:35pm
No, completely different due to the ACE (Active Cornering Enhancement) system fitted to the Disco2. Disco 1 might be though.
Post #847040 30th Jul 2020 1:50pm
bankz5152
I meant D1! Oops lol
Post #847044 30th Jul 2020 1:54pm
rallysteve
D1 front and rears fit Defenders fine but I am unsure if they have the same stiffness but must be similar as they are the same diameter AFAIK (based on the fact the bushes are the same diameter bore)
Post #847046 30th Jul 2020 2:01pm
bankz5152
That work then! Mates got a set i can have for free. Just need new bushes and some spacers to suit my lift
Post #847048 30th Jul 2020 2:04pm
rallysteve
Remember that you will need the wider bushes and the corresponding metal retainers for the rear ARB as the Discovery uses the same type as the 90 which wont fit your 110
Post #847056 30th Jul 2020 2:33pm
bankz5152
Noted! Thumbs Up
Was going to replace with Super Pro anyway and the brackets are £10 so easy Smile
Post #847083 30th Jul 2020 4:31pm
bankz5152
Just working more toward this.
I know ill need spacers to suit my lift which is roughly 2" on the front, little more on the rear as its a pick up.
I was thinking 25mm spacers should be fine?
Post #848625 8th Aug 2020 8:28am
