![]() | Home > Technical > Anyone know if D2 Anti Roll Bars are the same as Def 110? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2234 ![]() ![]() ![]() |
as above really chaps!
I meant D1! Oops lol
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
D1 front and rears fit Defenders fine but I am unsure if they have the same stiffness but must be similar as they are the same diameter AFAIK (based on the fact the bushes are the same diameter bore)
Steve 02' 110 TD5 Double Cab Rebuild Thread |
That work then! Mates got a set i can have for free. Just need new bushes and some spacers to suit my lift
Remember that you will need the wider bushes and the corresponding metal retainers for the rear ARB as the Discovery uses the same type as the 90 which wont fit your 110
Noted!
![]() Was going to replace with Super Pro anyway and the brackets are £10 so easy ![]() |
Just working more toward this.
I know ill need spacers to suit my lift which is roughly 2" on the front, little more on the rear as its a pick up. I was thinking 25mm spacers should be fine? |
