Home > Puma (Tdci) > NAS Lights Fitment Issue
trailbear
Gents
I have just finished fitting a set of genuine NAS Lights to the rear of the vehicle and have found that the
Rear door is in danger of smashing them if I open it too far.
I dread to think on what’s going to happen if the wind catches the door or if I park on a slope.
Is there an adjustment on the rear door that I am not aware of?
Surely this can’t be right, they are on Landrover plinths fitted in the correct position.
Any advice on this please.
83/4E89E82C-139B-413B-A650-2220E9B39844.jpeg[/img]
Post #844751 19th Jul 2020 6:25pm
trailbear
Sorry, not sure how they have ended up oriented like that, technology confuses sometimes!
Post #844752 19th Jul 2020 6:29pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
On the NAS Defenders, the lights were all fitted at the bottom. How you have it is non-standard. Maybe a gas door strut would help?
 LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #844754 19th Jul 2020 7:41pm
A comparable setup was used on the SVX specials, though.
To be honest, I've had NAS lights fitted on three different Defenders and the wheel always gets close. It's not an issue, though. Darren
Post #844760 19th Jul 2020 7:48pm
trailbear
This I believe is how the SVX lights were fitted so perhaps I should have said that then.
However, I surely can’t be the only person to have encountered this issue.
I have seen many on the forum fitting theses lights in this position.
Post #844761 19th Jul 2020 7:49pm
trailbear
For some reason, mines will definitely shatter my new and expensive set up😳
Post #844762 19th Jul 2020 7:51pm
Are you running larger than standard tyres, by any chance? Darren
Post #844766 19th Jul 2020 8:07pm
trailbear
265/ 65 R 18
Post #844767 19th Jul 2020 8:10pm
trailbear
I am thinking if that is the problem then perhaps a gas strut set up?
Post #844769 19th Jul 2020 8:14pm
trailbear
As will@LRW suggested
Post #844770 19th Jul 2020 8:15pm
mk1collector
Defender upgrades sell shallow plinths that may help. Ray
My build thread
Post #844772 19th Jul 2020 8:42pm
trailbear
I’ll have a look at that, I have the gas strut from another vehicle so may start there.
Post #844775 19th Jul 2020 9:06pm
trailbear wrote:
265/ 65 R 18
Hmm, on paper at least they're ever so slightly smaller than standard 235/85 16's. If your 18 inch wheels have a greater offset than standard then that might explain it.
It sounds a bit odd, to be honest. It'd be worth taking a look at the door stay to make sure that the stop is properly in place. Failing that, you could try adjusting the mounting of the body end of the stay forwards slightly, which could be enough to solve the problem. Darren
Post #844787 19th Jul 2020 10:17pm
trailbear
Thanks
I will have a look tomorrow and see where we go from there.
I do think that it is slightly odd though.
Post #844795 19th Jul 2020 11:05pm
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
I remember that I've run into this issues when i first installed the NAS lights with the stock spare, but I honestly don't remember how we fixed it. There must have been a screw that allowed adjustments or we added spacers or something. I remember after fixing this problem the door would not open up all the way like before. These photos are before fixing the issue, I couldn't find ones after fixing it with the stock spare carrier.
Later on when I got a larger spare, I've already changed to a frame mounted tire carrier that can be adjusted so I adjusted the carrier. I found this photo while we were working on the door, maybe it would help.
Post #844954 20th Jul 2020 10:15pm
