Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2245 ![]() ![]() ![]() |
genuine LR surround but with the original holes filled / painted..........then a Zunsport grill (bought from here s/hand)
longer term both the mesh grill and the aircon rad, etc. behind cold do with a light tidy up to be 100% more to suit myself than any real issue |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Fitted the X Defend steering lock protector today - followed LRA's post (thanks Darren!) and from our forum shop, the dummy OBD socket. Rgds.
Chris |
Started fitting the side opening tailgate kit from Purely Metal.....
The fitting to go over the anti luce needed filing for 30 minutes to get to fit, and the holes for the bolts are too small. The holes in the left hand fitting are too low so need adjustment. Maybe the fixings on the tailgate are odds and sods and not original. Regardless it was tremendously irritating trying to do a 15 minute job and not get close.... Perhaps this should be in the grumpy old man thread....😤 |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1770 ![]() ![]() |
Went out for tea MUD style. A big thanks to Kev for everything.
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
Decided to finally fit my Anderson connector...
![]() Click image to enlarge ...which meant splitting the winch...why is nothing straightforward. Anyway, at least I could get the winch and winch tray nice and clean ![]() Click image to enlarge. Then realised the tails weren’t long enough to mount the socket where I wanted ![]() ![]() Click image to enlarge Now to fashion some kind of bracketry - although the jumbo cable ties seem to be doing a good job ![]() |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 461 ![]() ![]() |
The original side sills were showing signs of wear, ie not. a lot of paint left on them! so decided I couldn't make it any worse so I'll have a go at refurbing.
I'm not overkeen on a lot of chequer plate, so I didn't want it to just look stuck on, so I thought I would do the whole of the sills. Got the original ones off, prepped them all up and coated in Raptor. It worked really well on my fire & ice black side steps so it should be OK. Got a new set of decent chequer plate sills to go over the top, prepped these and applied Rator again. Will wait for a week for it all to go off and then put it all back again, should look a lot better, and will match the side steps and bumperettes. Will post pics when finished but here are the parts. Original Sils and new plate to go over the top all ready: ![]() Click image to enlarge ![]() Last edited by ChrisDefender on 21st Jul 2020 1:54pm. Edited 1 time in total |
Novar Member Since: 07 Jul 2020 Location: Dorset Posts: 16 ![]() ![]() ![]() |
Continued my goal of buying all of 4x4overlander
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11012 ![]() ![]() |
![]() ![]() A very happy day for me as i drove Millie back home today ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1870 ![]() ![]() ![]() |
How does the temporary engine feel Clayton? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
It feels good at the moment Rosco, but its the injection pump ( used one )that is the worry at the moment, as it has not been used in a while, i will have to blow the cobwebs out a bit longer and see how she goes
Got all the refurb on the original side sills done as well as the new chequer plate. Very happy with how it's turned out - looks so much better than missing paint.
As with all things LR nothing is straight! so to fill the 2mm gap I used the self expanding waterproof tape to give a nice neat finish between the two parts. Just got the get the old bolts out of the floor panels now so I can add a stainless sill protector then these can go back on ![]() Cheers ![]() Click image to enlarge |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1369 ![]() ![]() |
After fitting a new fuel pump, new injector loom, injector seals, and having the injectors reconditioned, the TD5 is back on the road and pulling hard.
Should be good for another 100k now |
[/quote] Should be good for another 100k now
