![]() | Home > Td5 > Has anyone done a TD5 conversion from a 300tdi |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1657 ![]() ![]() |
lots of work to do it right cheaper to buy a td5 90.
for starters a td5 wiring loom and fuel pipes and fuel tank and cradle for the same plus lots more. plenty of build threads on the web which cover it in more detail |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
Well thats not quite true.
Conversions start at around £1800. Need a loom, fuel pump (Bosch 044), deimobbed ecu and a dressed engine. |
RILEY Member Since: 01 Feb 2013 Location: United Kingdom Posts: 35 ![]() ![]() ![]() |
Hi mate done a Td5 from 300Tdi pretty time consuming as said loom ,ecu,dash engine mounts fuel system doable but at current prices and probably better just to buy one
texpis Member Since: 13 Jun 2009 Location: Stockton-on-tees Posts: 52 ![]() ![]() |
This chap does wiring looms for td5 conversions
https://dixonfabrication.co.uk/index.php?r...path=87_89 |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
If you do decide to go a head, I would look at one that's been done in person if possible and talk to the owner. from my experience from engine conversions, I would take some internet info a pinch of salt, They may have you doing stuff that you dont need to do so.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
