Home > In Car Electronics > Solar panel wiring entry point help
rizga1
I fancy putting a solar panel on the roof of the 110 and I wonder if anyone would help me choose the best way of getting the wiring in to the vehicle please?
What route do you use please?
TIA.
Post #843315 12th Jul 2020 3:13pm
jst
Through door gaps...... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #843320 12th Jul 2020 3:23pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Stuffing gland through the roof with lots of CT1 to keep it there.
Thumbs Up
:edit:
one of these in case you're wondering what one is Mr. Green
Post #843336 12th Jul 2020 4:10pm
bear100
Do you have a raised air intake? If so you can run the cable inside.
Same with a rear ladder, the exit point can be underneath.
These are also very good and used widely in the marine market, the problem with stuffing glands is the mating surface and washer isn’t big enough and will eventually allow water to pass 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #843344 12th Jul 2020 4:35pm
Post #843351 12th Jul 2020 5:18pm
rizga1
Thanks everyone.
That scanstrut jobbie looks spot on as well.
I don't have a snorkel or a rear ladder so maybe I will put the entry point high up on the rear of the truck.
Post #843354 12th Jul 2020 5:32pm
miker
Did the same yesterday, made a couple of holes in the rear panel above the door and used a well fitting grommet
Post #843409 12th Jul 2020 10:01pm
izack98
Canada 2001 Defender 110 2.5 TD CSW Chawton White
Post #843562 14th Jul 2020 4:26am
