![]() | Home > In Car Electronics > Solar panel wiring entry point help |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
Through door gaps...... Cheers
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Stuffing gland through the roof with lots of CT1 to keep it there.
![]() :edit: one of these in case you're wondering what one is ![]() ![]() Click image to enlarge |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Do you have a raised air intake? If so you can run the cable inside.
Same with a rear ladder, the exit point can be underneath. ![]() Click image to enlarge These are also very good and used widely in the marine market, the problem with stuffing glands is the mating surface and washer isn’t big enough and will eventually allow water to pass 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Marine all the way.
https://www.defender2.net/forum/post810458...rut#810458 |
rizga1 Member Since: 14 Apr 2020 Location: QZ Posts: 28 ![]() ![]() |
Thanks everyone.
That scanstrut jobbie looks spot on as well. I don't have a snorkel or a rear ladder so maybe I will put the entry point high up on the rear of the truck. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791 ![]() ![]() ![]() |
Did the same yesterday, made a couple of holes in the rear panel above the door and used a well fitting grommet
izack98 Member Since: 25 Sep 2016 Location: Vancouver Posts: 26 ![]() ![]() ![]() |
I like these:
https://scanstrut.com/products-22/electric...ack-detail |
