![]() | Home > Maintenance & Modifications > ATB for LT230 |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
I have to agree with Blackwolf on gearbox / gear changes. In my limited experience any issues are usually a result of something else......and I include friction plate as being something else. that said I personally find the defender to be the most difficult vehicle I've ever driven in terms of getting nice smooth gear changes. |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Does anyone know what oil should be in a transfer box with Ashcroft ATB ? https://www.instagram.com/hustynminepark/
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Straight mineral EP90.
Nothing else. |
Thank you . Does it make a big difference to Semi 75w 90 GL5 and any particular recommendations ?
The reason I’m asking is because I’m having doubts as to what my mechanic put in ! https://www.instagram.com/hustynminepark/ |
I’ve been getting some persistent vibration through the drivetrain for sometime now and today took it to a garage in Launceston for a second opinion as nobody seems to be able to find the problem . Two hours later I got a call (impressed) to say that they are 99.9% sure that the transfer box has a bent output at both ends and has probably been in a severe shunt .
I hadn’t told them at this point that the Transfer box was a unit from Ashcroft with ATB and only 9 months old . When I did they said they weren’t surprised and no longer wish to deal with Ashcroft themselves . My defender has never been in an accident and has covered a mere 3000 miles since replacing the box . Has anyone got any thoughts on this ? It would explain a lot as all exploratory work into the vibrations has been on the basis that the transfer box is as new !! I have an entirely new drivetrain as a result and it’s cost me a small fortune https://www.instagram.com/hustynminepark/ |
I should add I’ve been in touch with Ashcroft but haven’t received a reply as yet . With videos of the unit vibrating . https://www.instagram.com/hustynminepark/
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
Hi Richard,
I have just emailed a response to try to get this issue resolved for you, Dave |
That’s great thank you Dave https://www.instagram.com/hustynminepark/
