![]() | Home > Td5 > Which starter motor? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Denso is choice of many
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6008 ![]() ![]() ![]() |
A few choices here
https://www.lrdirect.com/NAD101240-Starter..._https=yes 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1784 ![]() ![]() ![]() |
Do you definitely need a new starter motor?
The motor doesn't fail all that often, more likely to be the solenoid contacts. These are easy to fit yourself. |
If it doesn't work solenoid contacts as said.
If it turns slow, take it apart and clean the gearbox and pack with new grease. Sounds starnge but that will make a lot off difference. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 170 ![]() ![]() ![]() |
What are the symptoms?
New solenoid contacts as has been said. Worst bit is the PITA bolt.... |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Solenoids already been replaced and, wires checked and everywhere cleaned up so had the garage i use check everything over and hes sure it needs a new starter
In that case I probably would stick with denso
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8331 ![]() ![]() ![]() |
Dense for me Cheers
As i thought everyone would say i have gone ahead and gone for denso
Get the old one and check the gearbox I bet it turns difficult. Roel
