![]() | Home > Puma (Tdci) > noisekiller engine blanket highly recommeded |
You're not the first to sing the praises of this this product: -
![]() http://www.defender2.net/forum/topic4496.h...oisekiller http://www.defender2.net/forum/topic1183.h...oisekiller If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Could you post pics? ![]() ![]() IID Pro MV License |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
just back from work. Will do in the morning
![]() Click image to enlarge there you go what isn't visible in the photo is the flap that tucks down the back of the engine hence the L shape overall. You just have to bend it away from the exhaust manifold. You can also get an under bonnet kit but I think the blanket is better as it muffles the din at source |
I had a Td5 one which I shifted from vehicle to vehicle, it worked well. Steve.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4807 ![]() ![]() |
What is behind the plastic circle with Land Rover on it on the lefthand side of the engine? My 2008 Puma does not have this. 1982 88" 2.25 diesel
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
Its the cover plate for the air con compressor drive belt and pulley ![]() |
That explains it-I do not have airconditioning. Thanks
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Thank you mate ![]() ![]() IID Pro MV License |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
just wondering that this will do to the engine temp, esp in warm climates... --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
hmm expanding foam all the gaps should do the trick.....
Pom |
nikojo Member Since: 06 Aug 2011 Location: Madrid Posts: 75 ![]() |
Do you have pictures of how you did the wheel wells??
Did you just stick on top from the inside?? |
sorry nikojo just noticed this but no pictures I'm afraid. I just plastered it on from the inside and put the carpet back on - job done and hidden !
