![]() | Home > Maintenance & Modifications > 13 pin socket install Double cab |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
It's just to pick up an ignition feed for the ignition supply relay (the yellow relay in the kit).
Any of the white with green stripe wires from the switches will do, you will almost certainly probably have the HRW plug on your loom just not connected to anything - so you can still use it. ![]() ![]() |
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 ![]() ![]() ![]() |
Great, Thanks Martin. Tdci 110 DC
You're welcome
