Home > Maintenance & Modifications > 13 pin socket install Double cab
jwhat
Ireland 2008 Defender 110 Puma 2.4 DCPU Keswick Green
In the LR instructions it says to tap into the heated rear window switch but since I have a double cab (2008 puma) I don't have that switch. Does anyone know where to tap into instead or if the wiring is there anyway and I can still tap into it? Tdci 110 DC
Post #840664 30th Jun 2020 11:44am
Martin
Site Admin
It's just to pick up an ignition feed for the ignition supply relay (the yellow relay in the kit).
Any of the white with green stripe wires from the switches will do, you will almost certainly probably have the HRW plug on your loom just not connected to anything - so you can still use it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #840667 30th Jun 2020 11:52am
jwhat
Great, Thanks Martin. Tdci 110 DC
Post #840669 30th Jun 2020 11:55am
Martin
Site Admin
You're welcome Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #840670 30th Jun 2020 11:55am
