Home > Technical > Rebuilt gearbox |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
I don't think you can do that with any R380, it isn't a "fast" box.
30th Jun 2020 11:06am |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 129 |
My recon gearbox didn't feel much different than the original. Brand new gearboxes on the other hand, feel amazing. LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com |
30th Jun 2020 3:24pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 454 |
did the turret come with the box or did you fit your original one. If original, you will have to set it up for new box
30th Jun 2020 3:58pm |
charisme1 Member Since: 23 Oct 2019 Location: Paris Posts: 39 |
when I shift gently and slowly without High reving it, Everything is ok. Also I have to decompose well passing by neutral. Please see vidéo Link below. Is this a normal way for shifting gears in a defender ? Thanks a lot !
https://we.tl/b-HHWNivosyV |
30th Jun 2020 4:28pm |
I need to know first did the turret come with the recon box or did you fit your original one.
This piece |
30th Jun 2020 4:52pm |
Hi
Bias seems ok and aligned between 3 and 4 if this is your concern |
30th Jun 2020 9:44pm |
Report post Hi Bias seems ok and aligned between 3 and 4 if this is your concern |
30th Jun 2020 9:45pm |
Hi
Yes. When I shift gears slowly and with low rev. Everything is fine. I have to decompose well also passing by neutral. Please see vidéo attached. Tell me please if this is a normal way of shifting for a defender. Sorry for the noise of the wipers. Many Thanks |
30th Jun 2020 9:48pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
i thought for a moment the grinding noise was from the gearbox lol
1st Jul 2020 9:48am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 621 |
I thought it was Pepé Le Pew. JB
@Lodelaner Instagram Youtube greenlaning and other LR related content |
1st Jul 2020 9:53am |
Hi Mike Am I supposed to shift that way ? I can not high rev it more and shift faster from 1st to 2d and 2d to 3rd. The throttle is at half way. Not more for these gears. Thanks for your advice. Julien |
1st Jul 2020 10:23am |
Hi Jonathan Am I supposed to shift that way ? I can not high rev it more and shift faster from 1st to 2d and 2d to 3rd. The throttle is at half way. Not more for these gears. Thanks for your advice. Julien |
1st Jul 2020 10:24am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2077 |
Your gear change looks fine.
Have you attempted to adjust the bias springs to improve the gearchange ? Mo The Land Rover 90 - Many are called, few are chosen. |
1st Jul 2020 11:09am |
