![]() | Home > Maintenance & Modifications > Remap - Dynachip v BAS |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
A copy of the current map is sent including current parameters. You tell them any mods if any and it will be created ready to load yourself. My Alive tool allows me to view, delete DTC’s and change back if I wanted to. This is for a basic stage 1 map mind you. Above that you typically need physical upgrades anyway which is not so straight foreword such as updated intercooler etc. My concern with going higher would be the balance between longevity and performance. I’m quite happy with my stage 1. In what must be 6 years not one slightest gripe with it. 👍🏻 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
one thing to consider is if they come to your house or you take the vehicle to them its a one off remap and if you need to set it back to standard or someone else does (dealer) you have to pay for the map again.
Remote option you can set it back to std yourself. I have had JE Engineering, TD5 inside on my td5s and L322s, both were great stage 1 ones and no problems over over 100k each. remote BAS x2 stage 1 76k miles, mapped at less than 200 miles and going well on 110 and had another done remote Alive - Stage 2 on my soft top. All worked very well with different characteristics but then no two of my vehicles were exactly the same. IRB is the other one i would seriously through into the pot. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
