Home > Technical > Identify Where this rubber moulding Goes!
Page 4 of 4 <1234
nitram17
There looks like there is a slight raised lip where the rubber meets the top of the wing if that gap is not tight the water will drip into the channel and might collect .....i would personally seal it with silicone ........... lets know how you get on!
Post #835588 6th Jun 2020 9:47pm
bear100
Looks like it grew there!
Let us know your findings Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #835589 6th Jun 2020 9:57pm
Sulisuli
Fitted my eBay purchased rubber strip today on mine and SWMBO defender, nice snug fit and less than a fiver to do both defenders Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #835590 6th Jun 2020 10:05pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Not done it yet, but I will seal it to the bulkhead.
Initial impressions are it's better than nothing (currently). Rgds.
Chris
Post #835593 6th Jun 2020 10:21pm
nitram17
Lots of defender owners are happy to be taken for a ride price wise for parts.......... but that lr bespoke piece of rubber does stop a lot of water from water flooding the footwell......... the stuff you have sourced looks a decent enough replacement! Thumbs Up
Post #835598 6th Jun 2020 11:12pm
Ianh
The OEM rubber fits so it’s inner edge covers the bolt head that’s gone rusty and is tight to the bulkhead . No doubt water has been saturating that bolt due to the missing rubber, hence its condition. Mines fine yet I’ve still given that bolt a good soaking with acf50. But also considering some silicon to make a proper seal to the bulkhead. Noting you need to use the correct silicon as general building / bathroom silicon eats into metal as it’s acidic. The stuff they use on windscreens is good and does not set hard so easy to remove and reseal after if needed.
Post #835989 8th Jun 2020 7:55pm
Pacha
Thanks Ian - I will be using the Flexi car body work stuff. Rgds.
Chris
Post #835991 8th Jun 2020 8:00pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Used some silkoline on mine and now it’s leak free...well except when I park with the N/S/F wheel as the lowest point...so I don’t, Thumbs Up
Post #836004 8th Jun 2020 9:56pm
Page 4 of 4 <1234
