![]() | Home > Technical > Identify Where this rubber moulding Goes! |
| L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728
Rearward end of the bonnet side perhaps, think I've seen something similar to that around there. Check the other side and see if you've still got one left. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
It clips under the inside edge of the wing against the bulkhead. It's supposed to direct the water that runs off the channel on the bulkhead to dissuade it from ending up in the footwells. 2007 110 TDCi Station Wagon XS
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
https://www.defender2.net/forum/topic72156...=wing+seal
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| notxal Member Since: 20 Nov 2019 Location: Shropshire Posts: 89
Brilliant, yes it’s Under the bonnet next to the bulkhead on the wing edge as described by you. Thanks everyone.
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
I don’t have those but they look a good idea. Anyone got a part number or link to them?
LR 038612
| JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 171
Sorted out my footwell leaks - along with a fair bit of Capt. Tolley and some Silkaflex. |
Not sure if I’m being a tight Yorkshireman, but £20 for 8” of trim seal seems like a bit of a rip off. No?
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
Co1 i certainly agree, its a lot of £ for what is a small piece of rubber seal, but then its cheaper than repairing rust
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) Last edited by bear100 on 29th May 2020 7:12pm. Edited 1 time in total |
Hadn’t thought of it that way!
I wonder if it's the same as other seals? i mean is there another seal out there the same? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1262
I have had one on order with craddocks for weeks now...................
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
I’m pretty sure that, along with the Capt. Tolleys and other stuff, it sorted my footwell - which means I have dry mats and carpets - so worth it on balance I think. |
| Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781
Looks very similar:- https://www.ebay.co.uk/itm/Large-Finned-Ca...e4243c7c1f Rgds. Chris |
