Home > Maintenance & Modifications > Toyo Open Country MT 255/85 16
Page 4 of 5 <12345>
CarMan
Fact - turning circle not as good with ET11 Zu's and 255's as ET20 Wolfs and 235's
Feeling - ride is not as 'nice' with the Toyo's compared to 235 Wranglers
What pressure are folk happy to go down to with the 255's for road use with an empty 90 Question
Wolfs gone for refurb today in satin black and will likely be going back on soon . . . . . . . . . Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #835306 5th Jun 2020 5:37pm
Grouse
Why - turning circles for those tyre sizes and offsets should be exactly the same - the offset counteracts the tyre size - and the inner tyre sidewall to the the inner suspension / chassis is exactly the same - I have fitted both without issue - see piccies
 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #835360 5th Jun 2020 9:57pm
Grouse
I’m now running 255’s on Wolfs at 28 and 35 psi on 110 and wouldn’t go back to either 235 or 265’s Thumbs Up 2017 Range Rover L405 Vogue SE V8 Diesel #16
Post #835363 5th Jun 2020 10:03pm
CarMan
Thanks for the reply and without any scientific research I has assumed what your pics show - so I am intrigued
All I know is that I carefully set my steering stops to max lock with Wolfs and 235's and no rubbing. Fitted the Zu's and 255's and they rub hard on the spanner arms on full lock Confused Rob
Post #835364 5th Jun 2020 10:13pm
CarMan
I'm thinking the inner sidewall is the same but because the 255 is taller when on full lock the edge of the tyre turns further so that is what is restricting lock Question Rob
Post #835369 5th Jun 2020 10:17pm
Grouse
That could well be Thumbs Up - every single vehicle will be different as well due to suspension / spring sag as well. I found the limit of mine is exactly 265’s on 08 offset was the limit - anymore and it rubbed. I have tried most tyre sizes and have now settled on 255/85 and it’s perfect - anything else looks too small or is physically too wide. 285’s look good but the turning circle unfortunately is abysmal Confused Unless you have massively offset wheels 2017 Range Rover L405 Vogue SE V8 Diesel #16
Post #835386 6th Jun 2020 12:15am
JOW240725
I've done a few hundred road miles and have to say I'm still really impressed with the Toyo's.
 James
Instagram @suffolk_rovers
Post #835392 6th Jun 2020 6:52am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Done over 1k on and off road, excellent, and still quiet on road too....
Post #835701 7th Jun 2020 3:01pm
donmacn
I still wish I could find affordable BFG or similar AT tyres in 255/85/16 but despite hanging on for a while I’m not seeing anything come onto the market.
For those running these Toyos any updates or observations? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #933302 12th Dec 2021 7:05pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Don I'm running at set about a year now....they are as quiet on road as any all terrain i've ever run before and surprisingly well mannered on a wet road.
Not had any big snow yet, or deep mud so can't comment there but good on general farm tracks etc.
The 255 size really suits the 2.4 Defender with its lower down torque etc. but the standard Td5 struggles a bit on that size.
N.
Post #933322 12th Dec 2021 10:17pm
They suit the Puma well in that size, just go easy in the wet.
On my 90 I run 32PSi F and 34 PSi R tyre pressures. I have done for a long time now. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #933325 12th Dec 2021 10:29pm
donmacn
Thanks guys,
I knew the gearing would be slightly different, but what you’ve said Nidge about it not suiting a standard Td5 is maybe a consideration more than I expected.
My car is a 300Tdi. I have installed a VNT, and had the fuel pump tweaked to suit, and I have a Roamerdrive fitted. I wonder then if going to 255/85 might just compromise the use of the overdrive. Hmm.
Anyone with 300Tdi using these? I’d expect so…? Donald
in the past..
Post #933360 13th Dec 2021 9:55am
JOW240725
I run 255's on my old standard 200tdi 110 and it's been fine. I don't do many miles and only every trundle but had no issues. James
Post #933362 13th Dec 2021 10:00am
I used to run them on previous 90s, 200 and 300s. With a 1.4 t/box and little pump tweak they pulled just fine
On my current 110 I used to have them (td5) and it was great. I went up to a 1.2 box and it was horrible, t
Although I dropped back to 235s then
Post #933366 13th Dec 2021 10:23am
donmacn
Thanks guys - still in the running then!
A bit o/t but when I had the gearbox redone nearly a couple of years ago, I had a ‘V8’ 5th gear put in - it’s something offered by Ashcrofts, though I don’t have the detail to hand. It was just too highly geared for the car to pull comfortably around here. May have been OK in the “flatlands” down south… Whistle
That’s one of the reasons I eventually went for the Roamerdrive - a much more flexible option, and the reason why I want to be confident that going to 255/85 won’t cause me issues.
My future usage plans (once we’re as far past this Censored COVID Censored as we’re likely to get) is for long motorway runs to the south, heading for France, Spain or Portugal, or even north into Scandinavia, and then off road tracks or whatever. This is why I’d prefer ATs (currently on BFG A/Ts) but if they’re still not an option why I’m looking at these Toyos. Donald
in the past..
Post #933372 13th Dec 2021 10:44am
Page 4 of 5 <12345>
