![]() | Home > Technical > Identify Where this rubber moulding Goes! |
| JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 171
Windscreen vent pressings on a Puma - they couldn’t even be arsed to sort out a new bulkhead panel
| izack98 Member Since: 25 Sep 2016 Location: Vancouver Posts: 26
What about modifying something like this?
https://www.rubberonline.com.au/extrusions...25mm-p103/ Could possibly trim the 'D' shaped rubber to suit. $12.60 AUD (£6.80) per meter. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
It's not, it's for a towing electrics socket. It's nothing to do with a PTO. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
Except the genuine tow kits use a separate bracket, as far as I know there’s never been a kit which is designed to fit there!
1988 90 Td5 NAS soft top
2015 D90 XS SW |
That's true, although the socket does fit. I've often wondered if it was one of those things that seemed like a good idea at the design stage but then when the towing kit was developed they thought, sod it, it'll be easier to install if we just include a simple plate.
Regardless though, it's definitely not anything to do with a PTO. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Correct, not PTO related as my 1988 90 has no hole and it wouldn’t have been reintroduced:)
2015 D90 XS SW |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
I bow to your superior knowledge!and its still a stupid place to put a 5" hole! |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
Why do you say that? It does its intended job extremely well, even if it seldom gets used for its intended job. |
Hi black wolf.....I don't know about your truck but on mine it has the power of a mini black hole to attract crud ,salt water and therefore is a rust magnet. I know most rust on the crossmember starts internally where the chassis is attached but my view the gaping hole does not help.
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
There are bespoke rubber cappings to cover the hole, i cant remember where i saw them at the moment but you can have plain or land rover logo etc 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Found a picture
There's actually a group buy thread going on for those things at the moment. However I can honestly say that the recess isn't particularly a rust trap on mine, there are many places far worse for it. I do like having the trailer socket well protected and they seem to last a lot longer in the recess.
Horses for courses, I suppose! |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2539
I have a rear view camera sitting in there on my 110. Keeps it protected and out of the way
| Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781
eBay seal strip arrived today - just slid some on, will report back.
Click image to enlarge Rgds. Chris |
