Home > Puma (Tdci) > Oil Filters |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 253 |
Hi
Look up this Ford part number on the internet or ebay BK2Q-6714-AA , it's what you find inside the genuine LR box! |
30th May 2020 12:57pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
I don't think you will go wrong with either Mann, Mahle or Bosch. Also worth a look may be the Fram Tough Guard range. They have a special anti slip coating which helps when removing the filter. Defender 90XS SW
30th May 2020 1:41pm |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 136 |
Cheers Def90 & discomog 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
30th May 2020 1:45pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 242 |
I've always used the genuine ford ones on ebay. I once used a bosch from euro car parts and it was not as well made. 1953 80"
1987 mini city e 2011 90" |
30th May 2020 2:26pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
If it's for a 2.4 Puma. .. The Mann version doesn't fit snuggly on the spiggot in the housing and the Mahle one doesn't have plastic end caps. I would go genuine LR for Ford. 2007 110 TDCi Station Wagon XS
30th May 2020 4:48pm |
2.2 spin on type 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
30th May 2020 6:47pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
The OEM from Ford is Mann W7050
30th May 2020 7:47pm |
Deleted post. 2007 110 TDCi Station Wagon XS
30th May 2020 8:02pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
For the 2.2 the genuine filters from Land Rover are not expensive (unlike the fuel filter, ouch!)
Genuine means peace of mind for me, after all you’ve no warning an aftermarket filter is not doing a good job until your engine lunches itself. 2014 Keswick Utility 2.2 |
30th May 2020 9:34pm |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
I think that given the issues the early 2.2 engines had with oil pump failures, a genuine filter is not a very expensive item in the service kit.
Part numbers attached if it helps.. Click image to enlarge Click image to enlarge |
31st May 2020 7:02am |
