Home > Puma (Tdci) > Oil Filters
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Oil Filters
Genuine or MANN or Mahle , used Genuine but thinking about a change (No blue boxes) Thoughts folks? 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #834233 30th May 2020 12:42pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi
Look up this Ford part number on the internet or ebay BK2Q-6714-AA , it's what you find inside the genuine LR box!
Post #834235 30th May 2020 12:57pm
discomog
I don't think you will go wrong with either Mann, Mahle or Bosch. Also worth a look may be the Fram Tough Guard range. They have a special anti slip coating which helps when removing the filter. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #834239 30th May 2020 1:41pm
natyeo
Cheers Def90 & discomog 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #834240 30th May 2020 1:45pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I've always used the genuine ford ones on ebay. I once used a bosch from euro car parts and it was not as well made. 1953 80"
1987 mini city e
2011 90"
Post #834244 30th May 2020 2:26pm
Bluest
If it's for a 2.4 Puma. .. The Mann version doesn't fit snuggly on the spiggot in the housing and the Mahle one doesn't have plastic end caps. I would go genuine LR for Ford. 2007 110 TDCi Station Wagon XS
Post #834259 30th May 2020 4:48pm
natyeo
2.2 spin on type 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #834278 30th May 2020 6:47pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
The OEM from Ford is Mann W7050
Post #834299 30th May 2020 7:47pm
Bluest
Deleted post. 2007 110 TDCi Station Wagon XS
Post #834300 30th May 2020 8:02pm
UtilityTruck
For the 2.2 the genuine filters from Land Rover are not expensive (unlike the fuel filter, ouch!)
Genuine means peace of mind for me, after all you’ve no warning an aftermarket filter is not doing a good job until your engine lunches itself. Crying or Very sad 2014 Keswick Utility 2.2
Post #834306 30th May 2020 9:34pm
Rkcorry
I think that given the issues the early 2.2 engines had with oil pump failures, a genuine filter is not a very expensive item in the service kit.
Part numbers attached if it helps..
Post #834342 31st May 2020 7:02am
