Home > In Car Electronics > Focal ES100K speaker fitting clarification
Page 2 of 3 <123>
Stacey007
Over the past two weeks or so I've upgraded my system after finding my old amp during lockdown.
These speakers I just fitted over the weekend Smile
All plumbed in and sounds great, will post my install details on a separate thread Smile
Post #833585 26th May 2020 10:06pm
The Zee
newton-tony wrote:
All done - many thanks all for the guidance Thumbs Up
Final question: to find the optimum sound settings is this purely trial and error, based on individual preference/hearing (the sliders in the crossover boxes)?
Congreaulation on the install Thumbs Up
The +/- X dB sliders are there to help with both personal preferance, but also the location of the speakers realative to the primary listener. Just use a piece of music you know well, and tweak the sliders till you think it's best. (unless you time alignment or digital sound processing (DSP) in the head unit,, then use the HU) Zaid-M
www.DefencePhotos.com
Post #833633 27th May 2020 7:37am
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
Where do the wires come through the floor under the center dash ? Is there an access point there which I don't have to drill ? ( I'm not drilling holes in the floor). Do you thread it through from above the gearbox?
Post #833667 27th May 2020 12:28pm
CharlieDonuts
I'm a bit stuck and confused Embarassed
Today I wired in the power supply for the Focus 2:1 subwoofer
I measure with my voltmeter 12v across the GND / +12V terminals on the back
So I have power going in Thumbs Up
But I do not have any lights on the front.
I was expecting to press a button and the light come on.
The manual isn't really clear
Do I need to wire up the REM connection to turn the power on ?
I hope that someone can help Bow down
Post #835438 6th Jun 2020 11:33am
cold
Yes, the sub will not turn on until it has remote power from the Head unit
Post #835473 6th Jun 2020 1:52pm
CharlieDonuts
Oh mate. Thanks. Rightio on to the next bit then. Mr. Green
Post #835474 6th Jun 2020 1:54pm
landy andy
You can just bridge from the pos to rem for a test.
Post #835506 6th Jun 2020 3:47pm
The Zee
If your going to "test" the amplifier remote by bridging the power/remote : Please use a piece of wire with a 500mA fuse in it, since I've seen expensive Amps damaged by unfused bridging. Crying or Very sad
Bridging is ONLY to check an amp - not a solution, it's a trouble shooting technique. Zaid-M
Post #835638 7th Jun 2020 10:06am
yorkshirelandy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
The Zee wrote:
The FrL/FrR output refer to the speaker outputs from the headunit, if you have fitted better speaker cable from the headunit to your current speakers use that, otherwise use what is fitted, the crossover is best suited as close to the speakers as possible.
I hope the diagram above is clear (note power, and other connections + any subs/amps/rear speakers omitted for clarity)
Zee, do you have a drawing for how an Isub 2.1 would fit into this?
I’m also fitting the mud JVC double din which has RCA.
I’m just confused about using RCA and do I feed the crossovers from the HU or amp? '09 Puma 110 CSW XS
Post #842191 6th Jul 2020 9:24pm
The Zee
Hi yorkshirelandy
There are 2 options, the top one uses the built in amp in the headunit (HU), and is a quick way to fit the iBUS to the system, you will keep the ability to tweak the bass from the HU
the lower option should provide better sound quality but you may lose the sub control from the HU and have to use the remote on the Focal iBUS 2.1,
while fitting consider upgrading the cables from the iBUS to the crossover, and from there to the speakers - no point haveing great sound out of the iBUS, then shoving down c%^p quality cable to great speakers - think the weakest point in the system, speaker upgrade, HU upgrade, addition of a sub, soundproofing, cabling upgrade - all form parts of a jigsaw to better sound Thumbs Up
Any 12v connection will require a fuse in the system to protect both the cable but also the amp in the iBUS Zaid-M
Post #842254 7th Jul 2020 8:25am
yorkshirelandy
Awesome thank you Zee, very helpful!
I've had some great advice from the guys on here but you can't beat a good diagram Thumbs Up
I'll go for option 2 for better sound quality and upgrade the speaker cable while I'm at it! '09 Puma 110 CSW XS
Post #842276 7th Jul 2020 9:42am
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I'm back!
Now purchased the Focal IBUS 2.1, but I have a MUD cubby box secure locker so mounting under the cubby is not my preferred option.
I have seen others mount below the rear seats (I have a 110 Utility), but there does not seem to be enough room. Is this as simple as making a platform to mount the sub, so it does not overhang? Or some other (better approach).
From a quick Google search:
What I have under my rear seats:
Many thanks!
Post #845275 22nd Jul 2020 4:13pm
Stacey007
I have fitted one Rockford fosgate amp and a 8" punch speaker.
The Amp powers all the speakers and sub although I do have another amp for just the sub when I have time to fit.
Sounds great with the K2's upfront and rockfords in back Smile
Post #845279 22nd Jul 2020 4:30pm
newton-tony
A long delay to progress, as I am building a worksop in parallel! I have wired in the ibus 2.1 initially as your option 1 (using RCA). I will use for a while then no doubt move to option 2....
For option 2, where you mention taking the time to replace the speaker cable, do you just use the connector that came with the sub for the Fr R and Fr L outputs from the sub?
Many thanks!
The Zee wrote:
Hi yorkshirelandy
Post #860237 7th Oct 2020 11:24am
The Zee
Hi newton-tony,
When I referred to upgrading/replacing the speaker cable, i was looking at the cable from the front speaker through to the 2 channel output from the Focal iSub.
The iSub has both a speaker input (high level) for H/Us that don't have RCA connections, and RCA (Low Level) input for H/Us that do have RCA output. But next to the high level input (in a common connector) is the high level amplified output for FrL and FrR speaker.
Money has been spent on H/U, iSub, possibly sound proofing, but the cable that JLR have used to get the power/signal to the speaker is the cheapest they could get away with! Now your putting better quality and more power down those lines by using an iSub, best replace the wires/cable with something better allowing the system to “sing” to get optimum quality.
And whilst this may not be an easy job, since those cables may be folded into a loom, or cable bundle (so picking up interference and noise as well) giving the speakers their own cable route should improve the sound quality.
If your still stuck, and I can see your in Wiltshire, and any where near Boscombe Airfield, then we can do a socially distanced meet up and I can explain better. Just PM me Zaid-M
Post #860703 9th Oct 2020 7:47pm
Page 2 of 3 <123>
