Home > Maintenance & Modifications > Roof Rack Lights |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 315 |
My current lockdown job is tackling some bits of corrosion & treating my 110 to some dinitrol treatment.
But i'm starting to line up the next job, which I think will be to add driving lights to my roof rack. I have my eye on four 6" roadrunners. Are these any good? I'm also thinking I could take the high-beam signal from under the bonnet, take that back to a couple of relays in the battery box and run some cables under the truck back to the ladder, up the back of the ladder and along the roof to the front of the rack (avoiding drilling any holes). How has everyone routed their cables? Any pictures of your setups? Cheers |
25th May 2020 1:46pm |
Thanks. that sounds a much better idea.
So down through the gutter & then presumably through the soft filler between B pillar / roof / door frame? |
25th May 2020 6:57pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Click image to enlarge Click image to enlarge Click image to enlarge There are two cables going through that gutter.... one for the front, one for the rear |
25th May 2020 7:34pm |
When drilling into the gutter, start from the top and drill down, use a step drill, it’s double skinned and alignment is what it seems looking up, if you get my drift.
Then drill into the door frame, cut the door seal and silicone the lot up! |
25th May 2020 7:46pm |
Thank you, really appreciate the photos.
25th May 2020 8:52pm |
