Home > Maintenance & Modifications > Roof Rack Lights
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Roof Rack Lights
My current lockdown job is tackling some bits of corrosion & treating my 110 to some dinitrol treatment.
But i'm starting to line up the next job, which I think will be to add driving lights to my roof rack.
I have my eye on four 6" roadrunners. Are these any good?
I'm also thinking I could take the high-beam signal from under the bonnet, take that back to a couple of relays in the battery box and run some cables under the truck back to the ladder, up the back of the ladder and along the roof to the front of the rack (avoiding drilling any holes). How has everyone routed their cables?
Any pictures of your setups?
Post #833284 25th May 2020 1:46pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Instead of running cables that way, have a look at drilling the gutter, and running cables into the cab and down the b pillar. It;so simple and a neat job. I’ve done it both sides, and run the cables under the roof rack, unless y;u look, you can’t see the cables
Post #833312 25th May 2020 3:56pm
JPE
Thanks. that sounds a much better idea.
So down through the gutter & then presumably through the soft filler between B pillar / roof / door frame?
Post #833343 25th May 2020 6:57pm
2010Blackdefender90
There are two cables going through that gutter.... one for the front, one for the rear
Post #833356 25th May 2020 7:34pm
2010Blackdefender90
When drilling into the gutter, start from the top and drill down, use a step drill, it’s double skinned and alignment is what it seems looking up, if you get my drift.
Then drill into the door frame, cut the door seal and silicone the lot up!
Post #833360 25th May 2020 7:46pm
JPE
Thank you, really appreciate the photos.
Post #833366 25th May 2020 8:52pm
