![]() | Home > Maintenance & Modifications > Heavy Duty Hydraulic Crimping Tool |
I hope nobody minds me pulling a couple of posts from another thread and going off on this tangent:
https://www.defender2.net/forum/viewtopic.php?p=832757#832757
Thanks for the details of the tools posted
![]() I was favouring the type that has a steel pin insert rather than a C shaped arm to hold the die. It seems a better design and should be stronger in two similarly sized tools? I was trying to work out the difference between this - STEEL WIRE ROPE HYDRAULIC CRIMPING AND SWAGE TOOL YQK-300 at £119.99 ![]() https://www.gsproducts.co.uk/steel-wire-ro...ping-tool/ and say this one at £40.95: ![]() Click image to enlarge https://www.amazon.co.uk/ReaseJoy-Hydrauli...amp;sr=8-1 or this one -sold without dies for £228: ![]() https://www.s3i.co.uk/hydraulic-crimping-pliers.php |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
I would suspect the first 2 pictures are the same tool. Rgds.
Chris |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
The only real difference in quality between them that you will notice in use is the quality of the dies. They will all do decent crimps.
It is worth noting that the terminal shown crimped earlier (assuming there is a slit in the tube section which it looks as though there is) is not the correct type of terminal for a compression hex crimp. It should be an indentation type crimp I have had one of the chinesium ones for years and it is great. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I bought one of the 'YQK 240' ones from Amazon a few months back to make up some new battery cables for our boat. It was less than £38.
It works very well, but the dies are all too large for the numbers stamped on them. I had to use the 50mm ones to properly crimp a 70mm cable. There's a fantastic video here showing how to do the job properly: |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
I use the cheap yellow ebay hydraulic crimpers and they are spot on. Occasionally they leave a small flange of metal on the outside of the crimp, but some quick wiggle with pliers soon snaps those bits off. The head will also clamp into a vice which is useful for doing it by yourself. North Cumbria Search and Rescue - Team Leader
Thanks ~ I quite enjoy watching little videos like that. ![]() So does anyone know what the YQK in YQK 240 and YQK 300 stand for? I assume the 240/300 refers to the maximum size for the crimp. |
Yep - max crimp size. Rgds.
Chris |
Thanks.
Do you know what the YQK stands for? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17993 ![]() ![]() ![]() |
I think it is either the Anglicised form of the initials of the manufacturer, TAIZHOU YINDU TOOLS CO. LTD. in Chinese, or the Anglicised form of the initial letters of Yindu Crimping Tool in Chinese.
Thanks - I see they have quite a range of crimping tools:
http://www.yindutools.com/en/Products.asp?SortID=7#content |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
I used the crimp tool yesterday with 16mm2 Anderson connectors. The cable I was usin was a little smaller than the inside if the crimp end. I tried with a 16mm crimp and wasnt enough so stepped down to 10mm and that held fast.
For the price I paid, I am happy with it. Certainly makes the job easier. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
