Home > Puma (Tdci) > Short Shift SHIFT-R (V2)
Orchard
Hi all, just fitted a Short Shift-R v2 from TMD. First of all the machining quality and finish of this is superb and TMD are super helpful. Bow down
Fitting was about an hour, over half was taking out the carpets/centre console etc to get to the gearshift. Nothing tricky to do - just take care and follow the instructions - stuff plenty of lithum grease in the hole that the plastic cage goes back in.
What's it like to drive - wow! Thumbs Up
I have low mileage 90 but the improvement is huge, the gearshift has lost the stiffness and rubbery-ness, there's a satisfying mechanical feel to each shift. It does make a slight metallic clack-clack going into each gear, but I'm fine with that given how positive the shift now is. Don't expect a dual clutch speed of change - it's still a Defender, but very worthwhile update Very Happy Very Happy 2015 90 XS SW Bowler
1998 TD5 CSW
Post #770673 29th Apr 2019 1:33pm
JOW240725
Good to read positive feedback Thumbs Up James
Instagram @suffolk_rovers
Post #770695 29th Apr 2019 4:23pm
I'm really happy with mine too.
A bit of a thread revival but but thought I'd post this to show others TMD have a 25% off or similar offer on these right now.
Definitely is an improvement on standard, in fact I found my standard factory assembly was broken and I didn't know.
The nylon plastic ball joint had cracked, without disassembly you wouldn't know.
I wondered why I had poor gear changes, went to grease the system and only then did I find it was broken.
At the time it was replace Genuine vs Shift R, I went for the latter and it's been brilliant.
Thumbs Up Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~
I got’ love for Britain, I got’ British pride’. 🇬🇧
Post #832708 22nd May 2020 9:25pm
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Don’t forget to apply the discount coupon when checkout. Get another 5%
Post #832712 22nd May 2020 10:00pm
UtilityTruck
Unfortunately the discount is only 7%, at least when I looked. 2014 Keswick Utility 2.2
Post #832729 22nd May 2020 10:56pm
I’m not sure what discount percentages there are but they are a bit less than when I bought mine I do know. 👍🏻 Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
Post #832730 22nd May 2020 11:13pm
Michaelkan
I bought mine £209. Delivery included.
Post #832732 22nd May 2020 11:37pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I may go ahead and buy one , is there a forum discount code ? I couldn’t find one https://www.instagram.com/hustynminepark/
Post #832758 23rd May 2020 7:20am
LR90XS2011
before doing this it may be worth doing the additional locating bush mod DEFENDER 90 TDCI XS,
Post #832764 23rd May 2020 7:29am
cold
Did you use a discount code, its coming up at £220 posted on their site? If so could you possibly share it I cant find anything with searches?
Post #832902 23rd May 2020 3:56pm
Michaelkan
Will PM u
Post #832906 23rd May 2020 4:11pm
Good call, I did exactly that. Thumbs Up Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
Post #832913 23rd May 2020 4:43pm
cold
Post #832920 23rd May 2020 5:04pm
That's the one yes, I did all four on mine. Thumbs Up Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
Post #832941 23rd May 2020 6:08pm
