Home > Maintenance & Modifications > Webasto Top C |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 |
On top of that is planning to install the unit on a side locker at the rear of my Puma. If coolant can be integrated, will the distance to the engine be a problem? Thanks.
22nd May 2020 3:42pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7685 |
That unit will heat cab and coolant but will need a heat exchanger to heat water. You can plumb it to rear and pump will circulate fine. I use same setup and a 65kw heat exchanger to provide hot water for shower. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
22nd May 2020 8:38pm |
I thought Top C have a built in heat exchanger. I might be wrong. What heat exchanger are u using at the moment? Thanks.
22nd May 2020 9:51pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2078 |
It has but you'll be using it to heat coolant ! The Land Rover 90 - Many are called, few are chosen.
22nd May 2020 10:10pm |
Lol yeah. So what heat exchanger do u guys recommended?
22nd May 2020 10:51pm |
A 65kw one, loads on ebay, most from Poland. 1/2 or 3/4 male in/outputs. Cheers
23rd May 2020 7:39am |
Just bought a silencio ones. On top of that, do I need a calorifier?
23rd May 2020 7:56am |
one from poland arrived today ordered on tue last week, so a week including bank holdiay weekend.
Nordic Tec BA-12-30 - 65kw approx £90 with 4 x 3/4BSP male connectors. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
26th May 2020 3:38pm |
