Home > Maintenance & Modifications > Webasto Top C
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Webasto Top C
Guys need some of guidance. I need a heating solution that can preheat the car coolant, warms the cabin and provide hot water. Will the Webasto Top C do the job and do u need anything else. Thanks!
Post #832638 22nd May 2020 3:41pm
Michaelkan
On top of that is planning to install the unit on a side locker at the rear of my Puma. If coolant can be integrated, will the distance to the engine be a problem? Thanks.
Post #832639 22nd May 2020 3:42pm
jst
That unit will heat cab and coolant but will need a heat exchanger to heat water. You can plumb it to rear and pump will circulate fine. I use same setup and a 65kw heat exchanger to provide hot water for shower. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832697 22nd May 2020 8:38pm
Michaelkan
I thought Top C have a built in heat exchanger. I might be wrong. What heat exchanger are u using at the moment? Thanks.
Post #832710 22nd May 2020 9:51pm
Mo Murphy
It has but you'll be using it to heat coolant ! The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #832715 22nd May 2020 10:10pm
Michaelkan
Lol yeah. So what heat exchanger do u guys recommended?
Post #832726 22nd May 2020 10:51pm
jst
A 65kw one, loads on ebay, most from Poland. 1/2 or 3/4 male in/outputs. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832769 23rd May 2020 7:39am
Michaelkan
Just bought a silencio ones. On top of that, do I need a calorifier?
Post #832775 23rd May 2020 7:56am
jst
one from poland arrived today ordered on tue last week, so a week including bank holdiay weekend.
Nordic Tec BA-12-30 - 65kw approx £90 with 4 x 3/4BSP male connectors. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #833472 26th May 2020 3:38pm
