|  | Home > V8 > Stainless steel exhaust for a v8 - recommendations? |
| Fufflenarnia Member Since: 15 Feb 2020 Location: Redhill Surrey Posts: 13      | It looks great.
 Thinking out loud, it seems all the options only have a 2" or 2.5" single pipe, is that enough? It just seems a bit small... | ||
|  17th May 2020 10:15am |
| Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627      | I've got a 3" exhaust on mine and it is a bit loud, probably too loud (MOT advisory last time) | ||
|  17th May 2020 1:03pm |
| Fufflenarnia Member Since: 15 Feb 2020 Location: Redhill Surrey Posts: 13      | I like the idea to twin exhausts, I'm considering adapting a p38 system.
 I guess flow rate idnt that significant as we want torque rather than hp, but it must improve flow. Did you notice the difference when you went 3"? | ||
|  17th May 2020 1:18pm |
| Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 627      | Yes, it sings at above 4000 rpom, but is a bit sluggish below that.  I should have perhaps stayed with the 2.5" system I had previously, but I upgraded to John Eales Dakar manifolds at the same time.
 I toyed with the idea of twin exhausts and adding an exhaust valve like the F-type so that the second exhaust was only used when full throttle. Vacuum operated exhaust valves were available from Ferraris on ebay, but I didn't have easily accessible vacuum manifold to operate them. Cheapo chinese knock offs now available on ebay: https://www.ebay.co.uk/itm/Car-2-5inch-Exh...SwB21es4iB   Click image to enlarge | ||
|  17th May 2020 6:35pm |
| Fufflenarnia Member Since: 15 Feb 2020 Location: Redhill Surrey Posts: 13      | That's a very interesting thought, and a good insight.
 There are a few options for valves including using one of these: https://www.ebay.co.uk/itm/113559212594 Great food for thought, thanks. | ||
|  17th May 2020 6:58pm |
| Posting Rules
