Home > Puma (Tdci) > In a pickle
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
In a pickle
OK so got replacement swivel top pin collapsed new bearings and cv joint as totally shot all was going well till
I got re fitting shaft and cv pushed in through swivel but struggled to get it to locate right in so pulled to try again and cv came away
I now have shaft stuck part way not sure how to get out what a plonker any ideas anybody Endeavour To Persevere
Post #830962 13th May 2020 9:04pm
Is it worth pushing the cv back on again, give it a good clout?
It may relocate so you can try again? QRZ 2e0vpf
Post #830967 13th May 2020 9:38pm
110 Iain
Shaft is inside swivel housing may break circlip if I just bang on also worried about forcing at dff end so annoyed at myself
Will take swivel back of see if I can get grip off shaft it slid out no bother it just doesn't seem to want to go back smoothly Endeavour To Persevere
Post #830971 13th May 2020 10:05pm
jst
magnet on shaft? n42 style.
or remove swivel from axle and pull out. the relocate cv on shaft. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830973 13th May 2020 10:18pm
110 Iain
Not sure it will pul out by hand splines on shaft looked fine it went in to about an inch of being fully in and stuck and won't budge. By hand
Don't know about magnet thing my first defender keen to get back on road Endeavour To Persevere
Post #830978 13th May 2020 10:39pm
110 Iain
Thanks for reply got it out after taking swivel of got better grip got it back together now to do bearings it's a single nut set up
Want to change to two nut set up do spacers get ditched? Endeavour To Persevere
Post #831026 14th May 2020 12:02pm
Yes, remove and discard the spacer between the bearings and discard the stake nut. Instead use two flat nuts with the correct tab washer between them.
When reassembling with the two nut system you do not (of course) tighten the nuts stupid tight as you do with the spacer. Tighten the first just enough to eliminate end float on the bearings, then lock with the out nut and check how freely the hub spins. You will often find that the second nut pinches up the bearings due to slop on the threads, in which case release both nuts and try again with the inner nut slightly slacker. The aim is to get the hub to spin freely with zero end float when the lock nut is tight. When it is correct, bend the tab washer over one flat of the lock nut.
Post #831032 14th May 2020 1:14pm
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
a bit off topic for this thread but relates to swivel joint
i have just had to shell out £560 to get a swivel joint replaced after it took a heavy knock from a large stone whilst out laning.
it left a big dent in the swivel housing and ripped the seal. Has anybody come across a way of protecting the swivel more when
offroad? quite new to green lanes - does this happen often? the lanes are very rocky up here?
Post #843672 14th Jul 2020 3:07pm
In several decades of driving and working with and on Landrovers, I have never seen or heard of that happening, although I'm sure that it has. My suggestions would be picking you route more carefully, and be more aware of what is under the car.
Post #843699 14th Jul 2020 5:35pm
lakelander
Hmm interesting - thank you
was expecting just to have the seal replaced as it was leaking heavily, but the garage doing the work said it was badly dented and needed replacing. Sad
Post #843712 14th Jul 2020 6:17pm
110 Iain
Having just replaced both swivels on my 110 not sure how yours got a dent very unusual think you have just been unlucky this timwelcome to the world of landys Endeavour To Persevere
Post #843714 14th Jul 2020 6:21pm
lakelander
yes its sounds i was unlucky- why do swivel housings have to be replaced if not damaged? do they corrode. i see most repairs are just kits replacing the internals
Post #843728 14th Jul 2020 6:50pm
^^^ Pitting most commonly, and wear from the seal sweeping the surface.
Post #843731 14th Jul 2020 7:02pm
110 Iain
Hi I replaced mine due to leaks and corrosion did myself with help from Blackwolf and others on this forum by using this forum you will learn so much like myself a year in and I am a much more confident owner good luck Endeavour To Persevere
Post #843736 14th Jul 2020 7:14pm
