![]() | Home > Technical > Impact wrench |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Hog ring or detention pin what do you have🤔
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Several of each.
Generally ring up to 1/2" drive, above that I prefer pin. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2428 ![]() ![]() |
I’ve both. Prefer the hog ring, works well on my Milwaukee. I managed to break the pin on my dewalt and it’s no where near as powerful as the Milwaukee.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
I hate to be pedantic but I'm not sure that the retaining ring you're referring to is a hog ring. A hog ring is a connector used to fasten materials together using special pliers and is normally a permanent or semi permanent fixture.
![]() Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
Well Mr Dewalt describes it as a hog ring
and so does Mr Milwaukee. Like Blackwolf I prefer ring and pin for 3/4 drive and spring ring for 1/2" drive Defender 90XS SW
My reasoning is that a pin is more secure. Having seen sockets come off impact wrenches more than once, if you are hit by a 3/8" or 1/2" square drive socket it will hurt but is unlikely to maim. A 1" square drive socket is quite likely to inflict life-changing injuries, and is far too heavy in my opinion to rely on spring ring for retention.
I am not aware that spring ring is even an option above 1" square drive, the only system I have seen in 1.1/2" or above is the retaining pin. |
