![]() | Home > Series Land Rovers > 52HG25 lightweight series 3 |
Well as if 2 defenders, 1 90 and a disco 3 weren’t enough green ovals in my life I finally have fulfilled two dreams in one today, own a leaf sprung Land Rover and own a lightweight, talking to a friend he had lost interest in owning it due to a rough gearbox and a few other mechanical problems he wanted it gone, the price he asked was so good I agreed to purchase it for my fleet, now I just have to build a carport for her
![]() So here is 52HG25 as I picked her up today, she needs some parts to bring her back to military specs but that is something to happen over a while not an requirement straight away, with the summer coming and Guernsey getting the Covid-19 under control we should soon be allowed to enjoy summer days and evenings with the canvas off and a nice sunset in view ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Very nice. Good luck with the refurbishment, but it looks good anyway!
Relatively straight, chassis needs a clean and paint, foot wells will need doing soon, it’s mainly going over brakes/clutch etc
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2288 ![]() ![]() ![]() |
Cracker
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1910 ![]() ![]() |
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11063 ![]() ![]() |
Very nice Mash
What happened to the windscreen vents?
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1643 ![]() ![]() ![]() |
Nice one
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 412 ![]() ![]() ![]() |
Lovely
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Welcome to the gang 😎
Cheers guys
![]() The vent panel was extremely rotten so the PO had this plain one made and the old brackets cut off the original and welded to this one, did he remember to remove all the brackets/ fly screens etc? No did he ![]() ![]() ![]() Well after owning her for a few days and bleeding the brakes twice they still needed a double pump to get them to work correctly, the po said he had redone all the brakes a month or so ago, so with that knowledge a full strip down revealed a common mistake of reassembly. ![]() Click image to enlarge As you can hopefully see the spring has been connected between the two shoes apposed to the leading show and the pin on the back plate. This can cause a “spongy” brake pedal feeling, also the adjusting cams on 3 of the wheel stations had been hacksawed off and replaced with an aftermarket kit that was also incorrectly fitted causing the shoes to bind on the backplate and drum. With the brakes apart and finding an old tin of calliper paint this made sense. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Now the brakes are working well, onto the engine it’s a little sluggish to start and cuts out every now and then, well the original battery it came with was a gel battery that had m6 fixing so an extended bolt with penny washers made the connection ![]() ![]() Click image to enlarge The fuel issue turned out to be a slight seep from the lift pump to carb, a quick nip with the spanner and a little fettle of the idle adjustment and I’ve got a sewing machine under the bonnet ![]() ![]() With all that work done it’s definitely time for her to earn her keep: ![]() Click image to enlarge So the next few things to do, get a correct vent panel, find some S3 wheels or later defender steels, get the correct 7 leaf springs then some paint to get rid of the horrible ww2 American green paint (back to good old NATO green/black) oh and continue the search for a whole host of other parts ![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
![]() ![]() Excellent lightweight btw, what’s the history behind it? I assume there is a thread I have missed ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
05KD65 was the last lightweight registered with the military (in 1985) and spent 10 years with the Red Arrows being sold to its previous owner (who didn't know it was the last one....)
I've owned 05KD63 for 15 years and spent a couple of years looking for this one. It popped up on ebay a couple of years back and only 1 other person bid on it ![]() Currently stripped down while I rebuild her. ![]() Click image to enlarge |
Fantastic history that, always great to see the rare and unique ones saved and looked after 👍🏻 Will at some point soon ask for the merlin report on mine. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
