![]() | Home > Expedition & Overland > Henri the 110 goes pop top! |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049
Thanks for the answer Tim, i just knew there must of been a purpose for your design there
| Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025
Hi Tony, The pump is indeed a submersible ( Reich twin pump) it’s 18L per min & yes it serves three water points. One being the tap which is filtered potable water & then two shower points one rear panel & one off side back door for the quick pitch shower. The Bull finch shower points are mixers in their own rights so if you blank the hot water feed to them they become a basic flow switch from 18L per min to guessing 5L. Very impressed with how they work. |
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499
Just glad you sorted the x member .... that was triggering me with such a lovely build
makes a difference a bit of paint.....
Slowly getting there with the rear fit out, drawings are nearly there for the laser cutting.
| Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 284
Nice work Timcat . Gone are the days of beer mats to draw on
| kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277
Tim
It would be interesting to see how it works and if you can get a suitable pressure at the Bull finch shower point. I use a 7 litre shurflo 20 PSI in-line pump with an accumulator and a couple of filters (sediment bowl attached to the pump and a separate 3M in line). These just feed a single tap and the flow rate at the tap is really poor. I had intended using a bull finch shower point as well but the flow at the tap is so poor I abandoned that idea! Water containers are a couple of NATO jerry cans which I've had for years. I put an inline pump in because the neck is a bit tight to get a submersible pump in (and create a seal Tony |
Hi Tony, tried attaching a video but it won’t let me! Connected it up and it’s more pressure than my domestic shower at home, but it’s an 18L per min pump so more than double what you have at the moment.
Jim. |
Hi Tim
No worries, but thanks for the offer. I might have to get another pump |
So, rear o/s gull wing out & panel fabricated up a roughly fitted drilled ect to accept Peli 1720 case. It’s a good fit & suits our needs holding a service kit & recovery kit. That’s off to be powder coated now.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge It’s 155mm out from the side of the truck ( so probably 20-30mm further out than the rocksliders shower awning ect) |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
I like that, very neat, could have been designed for the job!
I think I would be inclined to fit a couple fo stays to the peli to hold the lid horizontal when opened (to act as a sort of tray, and also probably a bungee running the length of it so that if I had to open it with the vehicle on the tilt it stops everything falling out. it's the testosterone-rich version of the hairdryer box on the new Discovery Defender! |
| wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149
that looks really good and practical - love the idea and may ‘adapt’ it for Poppy!
Thinking of possibly using 2 boxes on that side mounted on air rails rather than one long box. - but still just thinking ! Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
| Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 412
I had the same idea myself but wanted to see what it looked like first, now i've seen one in place i'm happy that it's a great idea
Good points Blackwolf, ordered a couple of stainless stays & have a couple of stainless steel bimmi hooks that will accept a 25 mm cam strap to run from left to right. |
