![]() | Home > Td5 > JE Engineering stage 1 tune |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I think most tunes will give a small amount off black smoke below rougly 2000 rpm, above that there should not be any black smoke in my eyes. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1913
I had one a few years back and no smoke, but it did add more go, though I felt that perhaps it came in a little suddenly Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8488
I had one in 99 on my td5, je stage 1, loved it no smoke good economy over the 97k miles I had it. Went back to them for my l322. Cheers
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Stages are
Just have your car tuned to what you want it to do. Speak to Gareth at Empire he is ex JE. Brilliant guy and knows it all. |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
As above, I'd speak with forum sponsor Gareth at Empire Tuning! Does great work!! Will tune to suit your exact requirements, not just a standard tune.
| Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582
Have one on my 90. Done 11 years ago - can't fault it - great remap 2007 TD5 90 Hard Top |
| 90GTR Member Since: 05 May 2020 Location: London Posts: 201
Great to hear it, will likely be sending it down when lockdown eases off.
For the moment I don't really need something specific to my use. Its more of case of just waking it up a bit more ! It already feels better with the new air sensor! Whats the feeling regarding additional wear on the turbo / other components? Think this truck has about 108k.... |
Was my post removed ref empire? Cheers
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Yes JE did my tune on TD5 2006. Had the roof tent on at the time and when he took it for a test drive, approaching the roundabout way too fast, nearly rolled it. Big fright to us both.
Barely run in!!! Mines at 137k driven daily and putting out some chunky power at the min. Planning to go further shortly. That said I had the turbo off and fitted a hybrid within 2 days of getting my 110 Click image to enlarge TD5s are wonderful engines, very strong, very powerful (when done right) and very reliable. Gareth at Empire would run through everything with you, along with check the car over to ensure its healthy enough to take it. Post lockdow that is! Best bet is to speak to him. |
Around 1 year After my TD5 JE tune, I remember hearing a whistling noise when on throttle. Turned out to be cracked manifold, as a result of higher temperatures due to the tuneup. There’s always a negative somewhere along the line.
Keith |
| Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587
I'd echo that. http://www.empiretuning.co.uk/ |
| Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 804
I was under the impressions that stages of tune are related to the physical modifications done/needed to run that particular software? Regards Chris |
| MGDM4 Member Since: 28 Aug 2015 Location: Leeds Posts: 45
Everyone has different definitions of 'Stage x' so even that is hard to compare like for like.
As mentioned previously remaps should definitely not be done in stages as they should be bespoke to the owners requirements and the vehicles modifications. |
| All times are GMT |
