Home > Td5 > JE Engineering stage 1 tune
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
Recently bought a TD5 and want to do a stage 1 tune on it to make it a little more awake.
Previously owned a Stage 2 Tune+ vehicle from them a couple years ago but found the power a bit unnecessary for its use at the time.
Has anybody had a stage 1 tune done by them?
Hoping for one that doesn't splurge alot of black smoke all the time!
Post #829489 6th May 2020 10:14am
roel
I think most tunes will give a small amount off black smoke below rougly 2000 rpm, above that there should not be any black smoke in my eyes. Roel
2003 90 Td5 (2009-now)
Post #829533 6th May 2020 5:58pm
CarMan
I had one a few years back and no smoke, but it did add more go, though I felt that perhaps it came in a little suddenly Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #829536 6th May 2020 6:13pm
jst
I had one in 99 on my td5, je stage 1, loved it no smoke good economy over the 97k miles I had it. Went back to them for my l322. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829538 6th May 2020 6:20pm
bankz5152
Stages are Censored .
Just have your car tuned to what you want it to do.
Speak to Gareth at Empire he is ex JE. Brilliant guy and knows it all.
Post #829552 6th May 2020 7:49pm
JOW240725
As above, I'd speak with forum sponsor Gareth at Empire Tuning! Does great work!! Will tune to suit your exact requirements, not just a standard tune. Thumbs Up James
Instagram @suffolk_rovers
Post #829556 6th May 2020 8:10pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Have one on my 90. Done 11 years ago - can't fault it - great remap 2007 TD5 90 Hard Top
Post #829695 7th May 2020 3:54pm
90GTR
Great to hear it, will likely be sending it down when lockdown eases off.
For the moment I don't really need something specific to my use. Its more of case of just waking it up a bit more ! It already feels better with the new air sensor!
Whats the feeling regarding additional wear on the turbo / other components? Think this truck has about 108k....
Post #829782 7th May 2020 10:27pm
jst
Was my post removed ref empire? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829785 7th May 2020 10:39pm
keith
Yes JE did my tune on TD5 2006. Had the roof tent on at the time and when he took it for a test drive, approaching the roundabout way too fast, nearly rolled it. Big fright to us both. Shocked
Post #829786 7th May 2020 10:40pm
bankz5152
Barely run in!!! Mines at 137k driven daily and putting out some chunky power at the min. Planning to go further shortly.
That said I had the turbo off and fitted a hybrid within 2 days of getting my 110 Laughing easy to check wear on the turbo just pull the hose off anf give it a wiggle. Minimal lateral play is fine in and out play is not.
TD5s are wonderful engines, very strong, very powerful (when done right) and very reliable.
Gareth at Empire would run through everything with you, along with check the car over to ensure its healthy enough to take it. Post lockdow that is! Best bet is to speak to him.
Post #829803 7th May 2020 11:18pm
keith
Around 1 year After my TD5 JE tune, I remember hearing a whistling noise when on throttle. Turned out to be cracked manifold, as a result of higher temperatures due to the tuneup. There’s always a negative somewhere along the line.
Keith
Post #830739 12th May 2020 6:58pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I'd echo that. http://www.empiretuning.co.uk/
Post #830844 13th May 2020 11:18am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
I was under the impressions that stages of tune are related to the physical modifications done/needed to run that particular software?
Regards
Chris
Post #830848 13th May 2020 11:41am
MGDM4
Everyone has different definitions of 'Stage x' so even that is hard to compare like for like.
As mentioned previously remaps should definitely not be done in stages as they should be bespoke to the owners requirements and the vehicles modifications.
Post #873472 17th Dec 2020 6:50pm
