Home > Technical > Heated seat problem
jst
Heated seat problem
My drivers heated seat, back and base dont work.
Std lr wiring, factory fit.
When I got the vehicle there was no voltage to the seat base, neither elements heated. There was voltage to the back elements but it fudnt work and didnt make it from there to the base.
I fitted a new back heated element.
I now get voltage to the back element, as before, out of the back element and to the base element. But still neither work.
I assume there is voltage but no current.
Where is the earth for the standard lr wiring please for the heated seats.
Any suggestions welcome for finding a solution. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829305 4th May 2020 9:59pm
jst
Any thoughts please? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829438 5th May 2020 10:19pm
Balvaig
Try running a temporary power supply from the battery to the seat elements. This will establish whether they are working or not.
From there you can work back through the seat wiring and then the loom.
Post #829462 6th May 2020 8:11am
jst
Cheers, spare seat that works off its wiring doesn't work on drivers side so pretty confident it's the wiring not the elements. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829464 6th May 2020 8:36am
Martin
Site Admin
This is the 2.4 Puma heated seat diagram.
The (shared) ground point C0809 is on the engine bay side of the bulkhead, behind the coolant header tank, should be on the stud next to the one with the big multi-way ground header attached.
C1401/C1403 are the sockets mounted on the seat box.
Check the socket for continuity to a known good body/chassis ground on the black wire. Check for 12V on the blue/pink when the ignition is on and the switch is down.
https://www.defender2.net/gallery/albums/u...EATING.pdf  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #829484 6th May 2020 10:06am
jst
thank you martin for suggestions, will get on to it hopefully tomorrow Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829761 7th May 2020 9:02pm
jst
resolved, the heated element in the seat base was broken and not allowing complete circuit. have now replaced the element. So an 11 Plate with two new elements needed (back and base) of drivers seat - they dont seem to have lasted long! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830478 11th May 2020 4:08pm
htb2
Wales
Previous owner obese?
Post #830498 11th May 2020 5:40pm
jst
No idea. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830543 11th May 2020 9:42pm
