![]() | Home > Maintenance & Modifications > Sill rail replacement |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Morning
i have just taken mine off and replaced with rock sliders (much stronger, looks better and better side impact protection). On the 90 there are approx 5 bolts to undo on each side and over half of mine were so corroded they snapped off ![]() Worst ones were at the front end connecting bracket to chassis. Also...watch out for eyefuls of mud/dust Consider a better alternative to the LR sills as they are flimsy. Tommo |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
No welding required.
Cutting on the other hand...... you may find all your bolts rusted to the nuts, best to hope for them to snap! It’s worth making sure you have plenty of new hardware in case. Have a good look around all your fixing points before tackling the job and hit them with wd40 a few days in advance and then daily. QRZ 2e0vpf |
Hopefully you mean these, not side steps, as Tommo may be thinking of.
![]() Click image to enlarge QRZ 2e0vpf |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 ![]() ![]() ![]() |
Yep Greeni there the ones!
